LT250R Vacuum leak??
Old Mar 18, 2006 | 11:13 PM
OldBikeDoc's Avatar
Default LT250R Vacuum leak??
Fresh top AND bottom on 1986 LT250R. Boyesen Reeds, DG pipe, stock silencer. 260 main jet. Fresh plug, Uni pod filter.
Started it for the first time tonight.
Idles a bit high (even with idle screw all the way out) and choke makes little difference. Checked throttle cable, plenty of slack.
Within a few minutes the RPM's spike without throttle input.
I'm thinking vacuum leak somewhere?
Where do I start?
Help!
OldBikeDoc
Old Mar 19, 2006 | 09:13 AM
1987LT250's Avatar
my kehin carb i have to screw it in for idle to lower. but if you take catrb cleaner and spray it around intake boot it should stall it out when ya find the leak. if nothing happens pull your flywheel case cover off and spray around it it should stall it or bog it if seal behind it is leaking. good luck
Old Apr 5, 2006 | 11:03 AM
fergie's Avatar
Yes,pull the fly wheel off and check the seal.I just had the same problem.My seal had blown out,but was still in good shape,so i cleaned it up and pressed it back in.
ltrmc02
Aug 22, 2021 02:34 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Levi Enstad
Sep 26, 2015 08:00 AM
wrencher82
Sep 24, 2015 03:39 PM
