no spark for my warrior pleasae help
Old Mar 21, 2006 | 11:14 PM
maddmudder13's Avatar
Default no spark for my warrior pleasae help
my 1988 warrior ran great untill my starter clutch went out and i pushed started it a few times and rode it for a while but a month later i bought a starter clutch and installed it and i went to start it today and figured out it doesent have any spark. i took out the plug and grounded it and about every 15 seconds it would spark blue. this quad is makin me very angry so please help me out-jeff
Old Mar 22, 2006 | 05:21 PM
TRLYFZ450's Avatar
Starter clutch?
Is that the starter located in front of the engine
Or the one way bearing located behind the flywheel?
IF you had the stator and flywheel out. I would check all the wires coming out of the stator cover. Make sure the connections are clean and that no wires were cut.
Old Mar 22, 2006 | 07:16 PM
yeah a starter cutch is the one way bearing in there
would it make it not fire if i got oil on the stator? or does it run in oil regulary?
ill check these thing tonight
Old Mar 23, 2006 | 08:18 AM
lfowarrior's Avatar
I have a 2000 warrior and it lost its spark i replaced the pulser pickup coil and it fixed it for a couple of months then the same thing happened.This time i replaced the whole stator it runs fine now.
Old Mar 23, 2006 | 09:43 AM
so far ive narrowed it down to the coil so ive got to order one of those now so ill see what happens
Old Mar 23, 2006 | 09:10 PM
YamahaRider8998's Avatar
a similar thing happened with my warrior and i thought it was the starter clutch but my mechanic said it was the coil so i am waiting to ride it and check it out i get it bak tomorrow
steve
Old Mar 24, 2006 | 11:05 PM
giles45shop's Avatar
I had pretty much the same symptoms on my 87 Warrior. Very intermittent spark. I checked the resistances on the stator pickup coil and found one was out of spec per the manual. Bought a $40 replacement pickup coil from Ricky Stator and installed it. Works great now! Installing the pick-up coil was not too difficult, I re-routed the wires from the new pick-up coil in the wire track inside the stator cover and then out through the rubber grommet and then used a couple of crimp connectors to attach it to the existing wires.
Old Mar 25, 2006 | 02:08 AM
now what exactly is a stator pickup coil? is that the little box with two wires coming out of it? but i just ordered a ignition coil as that was out of spec but the way people are talking the stator pickup coil that you were talking about i think may be my problem
Old Mar 26, 2006 | 05:09 PM
so does anybody know how to a test a stator pickup coil? ive got the stator cover off right now and dont have any numbers to go by and how to test it.
Old Mar 27, 2006 | 11:56 PM
ok guys i finally found my problem[img]i/expressions/face-icon-small-smile.gif[/img], turns out the flywheel i bought along with my starter clutch was different than the 1988 flywheel. therefore not sparking at the right time and stuff, im so releaved now!
