no spark for my warrior pleasae help
Old Mar 28, 2006 | 08:22 AM
giles45shop's Avatar
Default no spark for my warrior pleasae help
Glad you got it fixed! If you do have other spark problems, you can test the pickup coil (the two little squares w/ 2 wires each inside the housing, without removing the housing. Follow the wires out of the feedthrough and you'll find a couple of connectors on the frame, kind of under the seat area. Get a Clymer's manual (~$30) and it will have the resistance values for the various wire color combinations. Check the resitances w/ a digital ohm meter and it's relatively easy to find out whether it's the stator or pick-up coils. If you really don't want to buy a manual, call Ricky Stator (www.rickystator.com) and they can give you the resitance values over the phone.
John
Old Mar 28, 2006 | 11:18 PM
maddmudder13's Avatar
ok thanks giles i knew there was a way to test it, my hanes manuel just didint say how to test it
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
