Recon ES won't shift
Old Mar 24, 2006 | 01:05 AM
ReconBayou's Avatar
Default Recon ES won't shift
'04 Recon ES won't shift electrically. The first gear indicator blinks 3 times - a break - and then 3 times again. For a while it was blinking 8 times. Owners manual don't say anything about any codes. After it has been sitting for a while it may shift a time or two before 1st gear indicator starts blinking and shifting stops. I was thinking battery power related but motor starts easily and lights work just fine. The indicator light will light up for whatever gear I put it in using manual tool but 1st still blinks, even if I have it in first. #1 What should I look for on the shifting problem and & #2 Is the first gear indicator light really blinking some kind of code?
Thanks.
Old Mar 24, 2006 | 10:29 AM
Sorek's Avatar
Sounds like the unit needs a service that intails changing a sensor or two......I have seen this problem many times in my shop with ES models which are ridden hard. The customers who ride it like a race quad or WFO all the time ALL HAVE THIS PROBLEM! There is a sensor in the tranny that is bad. Call a local Honda dealer to scedule a service.
Sorek
Old Mar 24, 2006 | 10:44 AM
ReconBayou's Avatar
Thanks. I don't ride it hard but this gives me a starting point. Looks like a trip to the shop if it is a sensor problem.
Old Mar 25, 2006 | 09:40 PM
ReconBayou's Avatar
Can anyone tell me where these sensor's are located? I pulled one near the shift shaft and cleaned it. Shifted well on the stand but no oil in tranny has kept me from riding it. If there are more sensor's I would like to clean/replace them all.
Old Mar 26, 2006 | 09:30 PM
ReconBayou's Avatar
For anyone that has this same problem - after adding oil and riding for about 1/2 hour it is shifting perfectly now. An early assessment is this sensor is the problem so I'm going to replace it with a new one and keep the original for a spare.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Jason Campbell
Sep 7, 2015 02:25 PM
