yfz 450 creeps forward ???
Old Mar 26, 2006 | 10:20 AM
bigP's Avatar
Default yfz 450 creeps forward ???
After I warm up my yfz450 I pull the cluch in all the way and shift into first I moves forward like the clutch wasnt pulled in. Then it stops after doing it a couple of times. Can some one tell me how to fix it. It only dose it when I start it up for the first time of the day and then gose away until the next day I go to start it.
Old Mar 26, 2006 | 10:23 AM
choosetolose04's Avatar
You need to adjust your clutch on the handle bar. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 26, 2006 | 01:31 PM
recon99's Avatar
Are you using the right oil? Other than that I don't know, sometimes the clutch plates just stick after it sits. Just press the rear break before you put it into gear. It's probably nothing with the adjustment if it goes away after the first time you start it.
My warrior does the same thing to me sometimes. It makes me look like an idiot, because I warm it up in my shed, then when I put it in gear it slams into the back wall of the shed and knocks all my bottles and parts off the shelf onto the quad and floor.
Old Mar 26, 2006 | 10:27 PM
lightning21's Avatar
i have an 06 yfz and it does the same thing, nothing to worry about, just clutch plates sticking..
Old Apr 22, 2006 | 05:06 PM
bigdeala102's Avatar
my 05 does the same thing. let the bike warm up before you ride
Old Apr 23, 2006 | 02:21 AM
LilJohn702's Avatar
My 06 450 does that as well. With the brake on and cluth in, the first start up will jump forward, after the first start up, it doesnt do it again. Im guessing something is just sticking until it gets a little use. I only ride mine on weekends, so all week it has time to stick. Hopefully thats all it is!
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bvandass
Oct 8, 2015 09:13 AM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
