mud lite or sur trak
Old Mar 26, 2006 | 09:13 PM
hillclimbingrecon's Avatar
Default mud lite or sur trak
I have a stock honda recon and ride on trails with steep hills and sometimes woth alot of mud which tire would be better.
Old Mar 26, 2006 | 09:18 PM
bal3wolf's Avatar
well i dont know about sur trak but i got mud lites on my rancher 4x4 and they pull great up hills they dig in good.
Old Mar 26, 2006 | 09:34 PM
Would the recons motor be able to pull the mud lite because all i want to do is put mud lites on the back. and do you go up in 2 or 4 wheel drive. also would the mud lite be a good all round tire for dry trails and hills and some times mud pits
Old Mar 27, 2006 | 03:39 AM
bal3wolf's Avatar
im not sure you would have to check tire sizes and stuff. I lost some power on my rancher when i went from a 24 stock to 25 mudlite not much but i did lose some.
Old Mar 27, 2006 | 08:07 AM
jonnyyellow's Avatar
yea if you get the 22x11-8, 22x11-9, ones they should be able to fit i think.. check your rim size and check your tire size now..
Old Mar 27, 2006 | 08:01 PM
my rim size is 22-11-9 would i be able to gain thre power that i lose when i put the mud lite on if i put a jet kit on? Ad is the mud lite a good all round tire
Old Mar 27, 2006 | 08:12 PM
bal3wolf's Avatar
put a jetkit on and a aftermarket air filter uni or K&N I proby gained 2-3 hp when i put my jetkit on after putting on mudlites for my 4x4 i can ride wheelies in 2nd now i couldnt do that with stock tires.
Old Mar 27, 2006 | 08:28 PM
thats what i am going to do any other suggestions
Old Mar 27, 2006 | 08:36 PM
Mud lights are my fav all around tire... good grip.. OK wear... ggood design... not to expensive.. and most of all light..
maby get a pipe as that will be able to help with power a lot.
https://www.fmfracing.com/products/c...&ItemID=041066
the fmf powerline is the only pipe i was able to spot quickly for the recon.. will help with power.. but would recomend jetting if you do get the pipe..
the tires should <u>not</u> rellly bog down the machine at all since they are the same size and all..
edit : should be should NOT as i underlined and bolded above ^ instead of should, as i had before
Old Mar 27, 2006 | 10:18 PM
would i need to buy a jet kit or would the dealership be able to increase the jet for me.How much did the powerline cost?
