loose plug threads
Old Mar 27, 2006 | 10:04 AM
squeege's Avatar
Default loose plug threads
I bought a new 05' 450 kodiak and when replacing the first plug it seemed that the threads were maybe tapped sh!tty from the factory. Now I am wondering if I can tighten the damn plug enough without stripping the head. Any suggestions? Thanks
Old Mar 27, 2006 | 10:25 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
if i were you i would just reference another owner of the same quad and find out if his is just as bad.
Old Mar 27, 2006 | 02:19 PM
hondabuster's Avatar
Ive got an 04, but its the same plug and head. Mine seemed fine. It should be able to handle the 13 ft/lbs thats called out for torque on the plug. Put a bit of anti sieze on the threads, and start it by hand, and then just go to 13 ft/lbs (which isnt much), and it should be ok.
Is this the only time the plug has been out? or did you buy it used?
Old Mar 27, 2006 | 02:25 PM
squeege's Avatar
This is the first time it has been out. I have had many dirbikes that never felt this loose...I can screw in in about half way and it has quite a bit of slop 3/4 way not much better, but I tightened it up (not sure I can get 13# out of it) Just worrying me a bit...
Ramman1
Aug 11, 2022 01:53 PM
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
Sandman2.0
Jul 21, 2015 09:03 AM
