Easy Off on the backside of your Fenders? That's Crazy!
Old Mar 31, 2006 | 12:43 AM
MYWAYOUT's Avatar
Default Easy Off on the backside of your Fenders? That's Crazy!
But it works.... Saved me a bunch of money on my atv insurance!
It saved me a bunch of time when I went to wash my ATV! Service Mechanic Clued Me IN!
Old Mar 31, 2006 | 10:27 AM
madmatt1971's Avatar
Use WD40. It is a water displacer and it won't let the crud take hold. Plus its cheaper becasue you can buy it by the gallon and places like Homedeopt. Just becareful around your breaks. Most of the people I ride with soak there bikes in it less the seat and the dirt and muck just falls off.
Old Mar 31, 2006 | 12:35 PM
MYWAYOUT's Avatar
Be careful with that stuff.... I have found you get a little WD on the plastic... it deteriates the finish... it is a penetrating oil....
For the most part you mainly wan't to fill in the pores of the plastic and make cleaning a whole lot easier..... I have been using pledge or a watercraft spray on wax recently... works good too! Safe on plastic.... Doesn't deteriate the the finish...
Old Mar 31, 2006 | 02:41 PM
IdahoSportsman's Avatar
I use no touch tire shine on the bottom side of mine. Keeps it looking shinny and new and when you wash it grim comes off easily.
Old Mar 31, 2006 | 03:29 PM
Hate to say this but WD40 is a water displacer. That what the WD stands for. That why you use in in your distributor when it gets wet. NIt's not penatrating oil. Someone found out that is has lubricating properties and called it peneratating lube becasue most cars don't have distributers anymore. It also works great on Smowblower imprllers and mower decks. Keeps the grass from sticking. if something is wet it will get in and dispalce the water. Car door hinges are a good example of that. I think that's why folks this is a penerataing lube. That's a topic for another day.
Old Mar 31, 2006 | 03:35 PM
See link from more info.
http://www.wd40.com/Brands/wd40_big_blast.html
Old Mar 31, 2006 | 04:28 PM
Polaris500HO4x4's Avatar
Yes WD is a water displacer so if it gets used on plasitc time and tiem again it will dry it out
Old Mar 31, 2006 | 04:33 PM
Primus's Avatar
WD40 will in no way harm plastic or even decals. When I used to ride and race motocross bikes I always covered them in that stuff. Makes them easy to clean, keeps them looking shiny, and protects from sun fade and rust. Good stuff. I even use it to clean tar and asphalt off my dump truck. Works better than anything for that.
Old Mar 31, 2006 | 04:35 PM
im pretty sure that WD will dry out plastic prematurely
MYWAYOUT's Avatar
Thats where you get the dull finish from.... I used when I removed the sticker residue and it was a poor choice... dulled the surface right out....
But I learned what WD stands for now!
I thought it came from Walt Disney and contained ferry pixels or whatever that stuff is.....
Anywho... back to the topic... keep that wheeler clean huh?
Until the next ride anyway!
