Replacing 04 Suzuki Eiger 4x4 Front Boot Problem?
Old Apr 2, 2006 | 04:37 AM
HemiMan8s's Avatar
Default Replacing 04 Suzuki Eiger 4x4 Front Boot Problem?
The other weekend I tore the boot that is close to behind the front right tire and was wondering if anyone knows the steps to get to and replace it? Thanks
Old Apr 2, 2006 | 12:30 PM
rolsmojave3's Avatar
is it the boot by the wheel or the diff.....They are easy to do provided you get the right clamp...the whole CV joint just pops off with a blow from a hammer.CV man This is where I buy my CV needs from. Great guy with great service
Old Apr 2, 2006 | 09:07 PM
HemiMan8s's Avatar
Well do I have to remove the A-arm or shock? Hopefully so because I've already gotten the bolts out of both and they still won't come loose so is there somthing else I've got to remove or just beat them off?
Old Apr 2, 2006 | 09:33 PM
you can if you like I suppose..if your going to take off the a-arms do it this way...take off the tire/wheel, unbolt the nut in the center of the hub, pull it all off. If you're not going to take off the a-arms...take off the tire/wheel, unbolt the nut in the center of the hub, remove brake caliper, pull hub/rotor combo off, loosen ball joint bolts, separate them, then pull the steering knuckle off, pop the joint out, good to go
Old Apr 6, 2006 | 01:59 AM
THECVMAN's Avatar
Hey! Thanks for the plug![img]i/expressions/face-icon-small-smile.gif[/img] Glad to hear the kind words. Keep spreading the word, I'm here to help.
neilbedwell
Nov 10, 2018 11:02 AM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
DOAinNY
Jun 11, 2015 10:34 PM
Dieseltrash
Jun 1, 2015 06:53 AM
cornermike
May 27, 2015 10:04 PM
