96 xplorer problems
Old Apr 3, 2006 | 11:04 AM
dugger13's Avatar
Default 96 xplorer problems
I have a 96 xplorer 400 4X4. It is running like crap. It will idle, but will only go about 25-30 mph. Seems there is no low end power at all. Sometimes have to put it into LOW gear just to get up hills in the woods etc... I have the atv completely stock. I took the clutchs apart and cleaned them and put them back together and it is doing the same thing. My questions:
1. the primary cluch has a blue spring with green marks on it? Is that stock, is there a better one to try.
2. the secondary has a red spring in it. I set it to whole number 3 and 2. Should I try a different spring?
3. I took the carb apart and noticed that when the throttle is at WOT, the float is still blocking some (about 1/4) of the round opening. Is that normal. I figured the throttle was fine because it idles and starts fine and also plug is nice and brown.
thanks.
From what i hear this quad should go over 60. Mine is definately not.
Old Apr 4, 2006 | 11:56 AM
dugger13's Avatar
Talked to a guy and he suggested it might be the reeds. Anyone else think that?
Old Apr 4, 2006 | 02:59 PM
CED's Avatar
CED
The stock reeds very seldom go bad.It sounds like the secondary,you should be set in the 2-2 position.You might not have wound the secondary right.
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
cornermike
Jul 8, 2015 11:44 PM
