Mojave Help
Old Apr 4, 2006 | 10:45 PM
JB2505's Avatar
Default Mojave Help
I have an 87 mojave and it seems like it tops out fast. BUT when i say fast i don't mean quick it just seems like when i hit 5th i have a lot of throttle left and it doesn't use it. Maybe im just crazy but is there anything i can do for more top end and not loose too much low end?
Old Apr 5, 2006 | 09:43 AM
holeshotz8436's Avatar
Default Mojave Help
what gearing and size tires in the rear are you running...it sounds like either your mojo dosnt have the power to pull the gearing/tire combo that your running because its geared too tall or you it could possibally be that your cams,valves and piston/rings need to be replaced just from 19 years of wear....d oa compression check and see what the psi is...it should be around 200
Old Apr 5, 2006 | 08:27 PM
JB2505's Avatar
Default Mojave Help
My engine was rebuilt like two years ago. So the piston rings and all that should be good. I have the origonal tires on it or at least the original size anyways and the gearing i am not too sure about.
Old Apr 5, 2006 | 09:02 PM
Default Mojave Help
count the teeth of your front and rear sprockets...stock is 12/43...and where did you get the idea that you got a .060 over wiseco in there...wiseco only makes pistons .020 and .040 over.....i still say do a compression check and see what kinda numbers you get...maby you blewe a head gasket? as far as getting some more power that cobra pipe isnt gonna help any lol........
Old Apr 5, 2006 | 10:57 PM
JB2505's Avatar
Default Mojave Help
Well hell i dunno maybe it is only a .40 but i know it is a wiseco piston. I just knew it was the biggest one so it prolly is a 40. The original was so screwed up thats how bad they had to bore 'er out. lol But yeah i'll count the teeth. It runs fine and all that it just seems like there is room for like a 6th gear or somethin lol. Its not doggy. As far as the cobra pipe goes i was told it was a good one for that quad and i've read on here that it isn't so hot so who the hell knows. But anyways thanks for the help though.
Old Apr 7, 2006 | 06:42 PM
rolsmojave3's Avatar
Default Mojave Help
what size tires do you have?
Old Apr 8, 2006 | 12:25 PM
JB2505's Avatar
Default Mojave Help
THey are like 11x10.5x22 or something like that. What size should i get for it?
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
