2000 300EX Running Issues
Old Apr 5, 2006 | 08:20 PM
Monte88's Avatar
Default 2000 300EX Running Issues
Hey, I just picked up my first quad, and i'm having a couple issues, possibly all related. I've got a 2000 Honda 300ex, with an FMS pipe/muffler, K&N filter, and an unspecified jet kit. Engine has a new plug in it, and he claims he adjusted the valves just before I bought it.
1. The bike will not idle when cold, even with full choke. Once its been driven for a couple minutes and is warm, it will idle fine. I was told this is a characteristic of the jet kit.
2. It runs great at full throttle and pulls up to limiter fine. When cruising at a constant throttle position, it sounds like its breaking up alot of the time.
3. When I shake it around alot, going over rough trails, or bumps it will die, usually when landing, sending my head into the handlebars. It will do nothing pushing the throttle in further, i'll have to release it, when the terrain smoothes out and then it will come back to life.
Ideas?
Old Apr 6, 2006 | 06:52 PM
Monte88's Avatar
TTT
Old Apr 6, 2006 | 07:52 PM
CoyoteRiverRaptor's Avatar
Monte, the 300ex is really cold blooded. One thing that helps with the cold blooded nature is to get an air tube from a 350X. This is the tube that goes from the air box to the carb.
The other problem sounds like a float problem. After all these years I wouldn't be surprised if that the little rubber tip is worn that closes the orfice on your float system.
CRR
Old Apr 7, 2006 | 09:45 PM
95wolv's Avatar
Sounds like you may have a dirty carb, I would first start with a disassembly and careful cleaning, making sure all the ports and jets are blasted out with carb cleaner,then blown out with an air gun. Then you need to find where you are on jetting, do a plug test to see if you are lean anywhere, and go from there. With the mods you have, you should start at 1 size up on the pilot jet, and 2 up on the main from stock, this will help your cold starting and idle. When you say it breaks up under constant throttle, that could be a lean condition in your midrange on the carb, when it is missing, hit the kill switch and coast to a stop and pull the plug, if it is dark, you are a little rich, if it is light tan or white, you are lean and need to jet up or raise the needle to richen up the carb at that speed. Dying when bounced around sounds like fuel slosh, your float level could be too low, starving your engine for fuel because the rough movements cause the low fuel level to allow air to be sucked in the main jet and severely lean out the motor.
Old Apr 7, 2006 | 11:26 PM
Monte88's Avatar
Sounds good.
Any literature online about rebuilding the carb? I can rebuild a Holley 4barrel in my sleep, but I know nothing about these carbs.
Old Apr 26, 2006 | 02:18 AM
vd's Avatar
vd
This is a float problem or (NEEDLE VALVE) for the stalling and cold blooded starts.
The cold blooded starting can also be
Loose exhaust causes backpressure evaporates gas too quickly.
Loose air box or dirty filter cuases backpressure, gas evaporation.
Incorrect plug for the quad
Old Apr 26, 2006 | 09:22 AM
Monte88's Avatar
Exhaust is good and tight....I took care of that when I bought the quad.
Air filter could stand a cleaning, but its not horribly blocked.
I'll have to check the plug.
Thanks.
Old Apr 26, 2006 | 10:29 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I agree, it is a float problem when it cuts out over bumps.
As far as start up when cold, the 300ex and 400ex are cold blooded, they won't idle when cold so don't worry about that, it is normal.
green giant
Jul 13, 2017 12:07 PM
wildbill59
Jun 20, 2015 02:26 PM
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
wbfjim
Jun 8, 2015 06:20 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
