bruin front tire adjustment
hey guys does anyone know if you can adjust the front wheels on a 05 bruin there wearing my outer edges of the front tires so im thinking must be camber or castor out of adjustment?
The only thing adjustable is toe in. It's normal for quad tires to wear unevenly, my front tires are doing the same thing. The tires are about a year and a half old, and the inside tread looks untouched, but the outer edges are worn out quite a bit. It' just from the weight transfer and sidewall flex during cornering.
hey recon hows it going again lol i looked at the tires they seem to be on alittle angle not straight never hit anything with it hell only a year old are the tires suppose to be angled alittle?
they're usually not perfect, if I look closely at my warrior it seems like the tires are a little closer together at the bottom than at the top, and my frame is all but brand new. The only possibilities I could think of would be bent a-arms or a tweaked frame, but if you never hit anything there's no reason for anything to be bent. It was probably always like that, and you just never noticed it before.
toonces
Oct 16, 2019 12:11 PM
