ignition switch removal
Old Apr 6, 2006 | 11:55 PM
arcticthunder's Avatar
Default ignition switch removal
how easy is it to remove the ignition switch. mine has the wires running to it cut, the bums were trying to hot wire
the machine but i interrupted them in the act. You should have seen them run after a couple of warning shots from
a Glock. luckily I live in a state where its legal to shoot first and ask questions later, at least the cops that showed up didn't hassle me about discharge of a firearm in city limits.
Old Apr 7, 2006 | 02:17 AM
fixitman69's Avatar
Most ignition switches are easily removed, but without anyone knowing what model of quad you have, nobody can give you a step by step procedure on doing anything. We need a little more info if we are to give you any helpfull advise.
Old Apr 7, 2006 | 11:00 AM
my quad is the trx350fm 2002 any help sure wouldnbe appreciated
Old Apr 8, 2006 | 01:06 PM
1988TRX250R's Avatar
Are you replacing it or bypassing it?
Old Apr 8, 2006 | 11:52 PM
i wish to replace it. just need an idea of the easiest way to pull the key switch off don't want to tear up the
instrument panel when removing.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
Desimation2k8
Jul 17, 2015 12:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
