Stripped carb bolt
Old Apr 8, 2006 | 05:31 PM
mrwake's Avatar
Default Stripped carb bolt
What can I do? I have one stripped carb bolt, what you do ? Retap it, dremel it or what other method. Im pissed.
Old Apr 8, 2006 | 05:45 PM
recon99's Avatar
Are you talking about the studs coming off the carb? How'd you manage to strip those out?
Old Apr 8, 2006 | 05:56 PM
mrwake's Avatar
Im talking about the scew with a phillips head on the very top. One little spin and she was done for.
Old Apr 8, 2006 | 06:12 PM
recon99's Avatar
did you strip the threads or the screw head?
stevendee's Avatar
if you are talking about the two bolts that go on the slide cover, the same thing happened to mine. i used small vise grips to get them out, then used a hack saw to make a new grove in the bolts to make it work with a flat head screwdriver.
Old Apr 8, 2006 | 09:53 PM
mrwake's Avatar
Awesome! What is the ballon like gasket? If I cant lock a pair of vice grips on them I will take the hack saw an cut the slot in them.
Old Apr 8, 2006 | 10:13 PM
Dunescreaminmama's Avatar
It's a known problem. Happened on my Warrior too. The stock phillip's head screws are a soft metal and whimpy. Best thing is to replace them all with steel alan head screws, especially if you're getting into your carb often to re-jet or whatever. Just had the RB carb mod done on my Banshee and Ron Black was kind enough to replace them all for me. I have no idea why Yamaha does that, but it is a b#$@$tch.
Old Apr 8, 2006 | 10:18 PM
mrwake's Avatar
Can yall post a link of a website to get these bolts from?
Old Apr 8, 2006 | 10:50 PM
Oops! I meant allen-head. Gosh, being a medical transcriptionist, I can spell duodenojejunostomy, but I can't even get ALLEN head right. Anyway....your local Yamaha dealer or motorcycle shop should have them, or even the hardware store. Probably quicker and cheaper. If you'd rather go on-line, try this RB Designs Mr. Black will set you up with whatever it is you need.
Old Apr 8, 2006 | 11:08 PM
mrwake's Avatar
He only deals in cash and checks so I wont deal with him. How much did getting your carb worked on help?
I would like to get him to do mine along with a little other work. Like clutch machiening.
