clutch slip with new tires
Old Apr 12, 2006 | 01:17 PM
DOOBOMB's Avatar
Default clutch slip with new tires
Hi im new here and i just put on a set of 22' mud lites well worked great with the minor mod's i have the first couple of rides. But yesterday i was out draging some freinds and in 5th gear the clutch would slip. So my question is could i put in 60% heavier clutch springs and solve this cause i don't really want to spend a hundred and seventy dollars on a clutch kit.
Old Apr 12, 2006 | 01:19 PM
FatHolly's Avatar
If you're clutch is already slipping you may have already glazed the steels. 60% springs will definetly help a good stock clutch but you may want to look into a new one since its already slipping.
Old Apr 12, 2006 | 01:27 PM
DOOBOMB's Avatar
What clutch would be worth the money stock or a aftermarket ? Cause i seen some problems with the Barnett clutch when i was searching the form.
Old Apr 12, 2006 | 01:29 PM
Camds650's Avatar
Mine did the same thing, Sanded the steels put in 60% springs and it's good. That was almost 2 years ago. Just measure them to make sure they are within specs.
Old Apr 12, 2006 | 01:31 PM
DOOBOMB's Avatar
Thank's I will try this first.
Old Apr 12, 2006 | 06:24 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Sanding Clutch Disk
Old Apr 12, 2006 | 09:21 PM
yjacket2001's Avatar
OMR, that's pretty slick. These clutches are pretty high, so that will come in handy.
What is your take on clutch springs? Do you have a preference on spring tension? I'm not sure about what the measures are since no one
says foot pounds, psi, etc... F650 riders (1/2" thinner clutch basket - one plate less) have had problems with the Pami 80% springs breaking other stock components. Seen some digital pictures on this site too with cracked clutch basket ($380), and transmission problems. Its hard to say what causes what, but I try to eliminate causes. There is significant engineering in changing oem components safely.
I did an assembly stack analysis and the 9 plate barnett kit, and 8 plates could add one on mine (7 stock), but the total disc stack warpage variance of .15 mm(!), was reduced by a third theoretically. So if it didn't wear faster than it warped, it may break something too.
Thanks for all of your help!
Old Apr 13, 2006 | 12:22 AM
OMR's Avatar
OMR
On the 2000 and 2001 I have used the 40% springs from RW.
On my sons 2005 we are using the 60% from HPR.
All are used with oem clutch.
The 01 is still on the original clutch.
Maintain the disc every 2 years, good oil, lube your clutch cable often, and run a balance tire/gear ratio for your driving useages.
If you trail with 22" tires and 16 tooth front sprocket, do not do alot of dragging unless you are in very loose dirt or sand. Install a 14T when you are on tight trails or dragging.
Size of rear tire and gearing have big effect on clutch wear. The people who have trouble with the stock clutch with heavier springs usually also have trouble with aftermarket clutches.
Old Apr 13, 2006 | 06:22 AM
DOOBOMB's Avatar
OMR, That's great info thank's.
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
