360 performance issues
Old Apr 13, 2006 | 06:53 PM
dusty12's Avatar
Default 360 performance issues
my 360 has become very sluggish ... difficult to idle ... cutting out when travelling and coming to a stop. this is rather frustrating. any thing i can try before going to the dealer .... I've changed the plug and cleaned the air filter???????
Old Apr 14, 2006 | 12:11 AM
Camoprairie's Avatar
Try adjusting your valves on the high side of the recommended tolerance.
Old Apr 15, 2006 | 07:40 PM
sandpit's Avatar
Yup.
Mine was an 04,and adjusting the valves did the trick.
Old Apr 24, 2006 | 08:27 PM
ColoradoBubba's Avatar
Same here, adjust the valves. My acting like it was starving for power and got worse and worse finally wouldn't start!
Old Apr 25, 2006 | 08:25 AM
dusty12's Avatar
How do I go about adjusting the valves. Is there some easy way of doing this????
I am not blessed with mechanical talents. should I bring it to a dealer
Thanks for everyone's help
Old Apr 25, 2006 | 10:17 AM
I bought a service manual and did it myself. I think you remove the fuel tank and maybe a inner fender splash shield. Also remove a side cover access plug to view the crank timing. Use the pull start cord to turn motor over to TDC. Remove the valve covers and and then use a metric feeler gauge. The feeler gauge is hard to find and I under stand if you need to adjust the valves this can take some trial and error due to lock nut, tighting the lock nut will cause the adjustment to change somethings.
But overall it is pretty easy, I'll never pay to have it done again.
COFatboy
May 2, 2020 12:06 AM
Nondem
Feb 22, 2020 12:20 PM
Asaran
Oct 8, 2015 11:14 AM
Unzzy66
Jul 11, 2015 10:01 PM
