why are front tires bigger than rears?
Does anyone know the engineering theory behind having 22 inch tires on front and 20 inch on back? I just put on 22 inch Holeshots on the rear. Should I leave the 22 inch fronts on or go to a larger size or does it make any difference? Thanks.[img]i/expressions/face-icon-small-confused.gif[/img]
once my stock 20's were bald, i put on some 22"s and it felt the difference immidiately, it seemed to me like i was very tippy and i couldnt take really fast sharp corners without it making me wanna tip over, so i bought some new 20's and it handles so much better
Allot of this all comes down to how the weight of the quad is shifted. If you put larger tires in the back it will put more weight on the front tires. To keep it loaded correctly you need to up size all 4 tires not just the rears. You can see how this could play out better for sand drags if you had mini's in the front to keep the nose down.
I run 22's front and rear, you will be fine chouser. but ideally the 23's in the front with 22's in the rear will handle better.
DS's have less caster angle in the front end geometry than other quads, this makes for a little more sensetive steering that some complain about, however this less caster also allows for a tighter turning radius. the DS is so long and wide that the turning radius is a bit larger than alot of other quads, and this less caster helps to combat that, with a price of handling at higher speeds from the sensetivity.
so anyway, with that being said - if you increase rear tire size without increasing front tire size, you decrease caster even more. but maintaining a larger front tire than the rear will maintain stock caster angle.
motor cycles and atvs are almost always designed with larger tires on the front because its way more important that your front tire isnt stopped dead by a rut or severe bump. a larger tire will traverse a larger rut without dropping into it. I once had an xl350 honda enduro motorcycle that had a 23 inch front wheel. it was a monster but the rear was only an 18. I also once had a mini bike with a 6 inch front wheel and one time while ridiing through a grassy field I found some 4 wheel drive pickup ruts that had been left by somone the previous winter which were now hard but 12 inches across. I was only doing about 25 but didnt see them coming. you can imagine what happened.
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
22's 4 the rear & 20's 4 the front... Makes the quad look kool with the little tilt to the front... where i'm from there is a lot of mud. So i'm gonna put bigger tires in the front after these 1's wear out, so i can get more clearence.
JackTheKing
Jul 14, 2015 09:09 PM
