How to do Valve adjustments
Old Apr 25, 2006 | 08:29 AM
dusty12's Avatar
Default How to do Valve adjustments
It has been recommended that I adjust the valves on my KVF 360 to the high side to improve performance.. next question???????
How do I go about adjusting the valves??? Is there some easy way of doing this????
I am not blessed with mechanical talents. should I bring it to a dealer
Thanks for everyone's help
Old Apr 25, 2006 | 10:01 AM
squeege's Avatar
Chances are you will be removing the fuel tank and maybe front plastic...then popping the recoil pull start cover off or whatever to find a timing mark to get top dead center...next you pop the caps off above the valves...you should be on the compression stroke.....stick the feeler guage between the top of the valve and bottom of the rocker arm and gap it in the specs for your bike using the nut to tighten or loosen the gap.... tighten the lock nut and put it back together....
PS..Get the service manual or have it done by a mechanic
Old Apr 26, 2006 | 02:02 AM
kawiyowee's Avatar
good post squeege
Old Apr 26, 2006 | 12:11 PM
Hayashi's Avatar
Another helpful tip is the use the "angled" feeler gauge instead of the straight ones. The space at the valve cap opening area is quite limited and the straight one is little difficult to manuver around. Also, 360 seems to need quite more attention on the valve adj than other Kawi bikes. Once you do it, then you will have the confidence to do it for the rest of your life.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
