'95 425 Magnum-carbon fouled and missing
Old Nov 19, 2000 | 01:28 AM
Kanard's Avatar
I hope somebody can shed some light on this one. About 1 month ago I noticed the machine would miss and seem to lose power, we replaced the air filter and the problem went away. But now it is really bad and fouling the plug with Black carbon and I cannot get any top end at all. I pulled the carb and cleaned all the jets,etc and set the idle and air mixture needles as per manual but that just seemed to make things worse. If I rev it up it just puts out extremely black smoke and backfires alot.
Can anybody shed some light on the black carbon? Could this be ignition timing? I cannot get the rpm's to settle down at 3000 or under.
Help... Hunting starts in two days...aarrghh!! always something to go wrong
Old Nov 19, 2000 | 04:34 AM
Charlie's Avatar
Pull the speed limeter black wire and if the problem goes away replace the module. If not then the camshaft has worn flat on the exhaust lobe.
The new cam is a lot better with larger and more oil holes and better hardfacing.
Old Jan 21, 2008 | 12:41 AM
goodblasson's Avatar
Default '95 425 Magnum-carbon fouled and missing
I am having this same problems... Does anyone have a fix?
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
