95 Magnum 425 idle
Old Jan 10, 2007 | 01:41 PM
mag425's Avatar
Default 95 Magnum 425 idle
my 95 magnum 425 only has 2200 miles on it. Brought to a guy for a tune up ( big mistake) ever since i got it back i have had nothing but trouble. Most recently it has been fouling plugs within a few miles of a new one being put in. The plug is black, I cant remember if this means too rich or lean?? I have replaced the air filter. When it idles it will vary in idle speed on its own and sounds "jumpy" from time to time. Could this be just a simple carb problem? the boots on the carb do not seem to be cracked or loose but I have not inspected them real close. or could this be much worse such as a possibly worn lobe on the cam? Any help would be appreciated.
Old Jan 10, 2007 | 04:54 PM
cornbread2's Avatar
The slide needle and nozzle in the carb are worn out. This is a common problem with the 425. They must be replaced often.
They will make the machine run very rich and foul plugs. After they get really worn they will not idle.
Old Jan 10, 2007 | 05:07 PM
mag425's Avatar
Where do I find the slide needle and nozzle in the carb??. Never torn into a carb myself but i have seen others do it. First timer here.
Thanks
Old Jan 10, 2007 | 05:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
was it running good b4 you had it tuned up?mabe this guy back it back togeter wrong. if its black its too rich and if it had a cracked boot it would be lean not rich. maybe the air srew is adjusted wrong as well. a couple of idears.
Old Jan 21, 2008 | 12:54 AM
goodblasson's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cornbread2
They will make the machine run very rich and foul plugs. After they get really worn they will not idle.</end quote></div>
Can you please elaborate on the nozzle and slide needle? I am having the same issues, fouling plugs and no power at all. I cant figure this out, please help!
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
Sep 9, 2015 06:57 AM
