Wobbley tires
I have brand new 26" swamplites, and at 5psi they seem to wobble a little, as i can feel it in the quad on a tar road. At 8psi, its alot better, but someone told me to run them at 5psi. The rating on the tire says "max load 550 lbs at 7psi" Should i stay at 5, or go to 7, or what? Any advice appreciated
These are heavy machines and I think that running one with low air pressure is asking for trouble. Losing a bead is probably a very real possibility. I run about 7-8 psi and still get the beads "biting" in fast turns. I will air down some if terrain dictates but only for low speed crawling.
Sep 30, 2015 01:37 AM
