84 Honda 110 ATC Carb?
Old Apr 29, 2006 | 05:47 PM
Tiger1256's Avatar
Default 84 Honda 110 ATC Carb?
Hello, Looking for some help. I just rebuilt the carb., replaced the intake gasket by the mouth of the carb. I can get the atc to run on choke but as soon as I take it off it will stall. It will start on the first pull on choke. I have the carb. set at 1 1/8 for the air mix screw. I have checked for other air leaks by spraying carb. cleaner around the carb but no signs of any other leaks. It will idol fine with the choke on but not with it off. At this point where can I buy a carb. for it if I need one. Where do I go from here?
Old Apr 29, 2006 | 10:52 PM
trav300ex's Avatar
Did you have it running properly before, and something happened? Check your jetting, is it smoking at all? Clean your filter, too.
Edit: also check here, might want to post this here actually
http://forums.atvconnection.com/cate...m/catid/15.cfm
Old Apr 29, 2006 | 11:52 PM
Fear's Avatar
could the float level be set to low ?
Old Apr 30, 2006 | 10:16 AM
Tiger1256's Avatar
I just pick this machine up. All I could get it to do when I first started it was idol. I broke down the carb and the jets were clogged so I cleaned it out and put the carb. back together and it ran better but would not idol. I order a rebuilt kit thinking that the gaskets and o-rings where bad. I change everything that came with the kit. Put it back together. It starts better now that I did that but will only run on choke. I didn't change the spacer between the intake and the carb, didn't come with kit. Should I try to find one?
Jmuddin284
Jan 19, 2026 07:16 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
