more speed out of a 400ex
Old Apr 30, 2006 | 08:47 PM
whitebrothers's Avatar
Default more speed out of a 400ex
with a 440 bigbore kit a whitebros pipe a new rear sprocket new valve springs to go with a new stage 2 hotcam kit and having my400ex jetted and burnin 93 octane fuel...do u think my top speed will be any greater??
Old Apr 30, 2006 | 09:11 PM
crashby's Avatar
i would hope so
Old Apr 30, 2006 | 09:12 PM
okbeast's Avatar
Compared to stock? Um....yes!
Old Apr 30, 2006 | 09:17 PM
how fast do u thnk it will go with all the upgrades???
Old Apr 30, 2006 | 09:34 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
it will go as fast as u gear it to go, i'd say you could pull 80 mph if u gear it right
Old Apr 30, 2006 | 10:37 PM
superevil's Avatar
Someone just came out with a 460 kit,it comes with piston/rings/sleave/cam and exhaust and they said it makes the power a little more than a 450r
Old Apr 30, 2006 | 10:47 PM
realy im goin to have to look into that....do u know wut the price on it is???
Old Apr 30, 2006 | 11:18 PM
if i put the 460 it on my 400 how fast do u thnk itl run?
Old May 1, 2006 | 11:43 PM
crashby's Avatar
Curtis Sparks make a 465 kit...http://www.sparksracing.com/frame_1.htm
Old May 1, 2006 | 11:52 PM
Sparky8370's Avatar
Well with more power you can run taller gearing which will give you more top end. But you can build it all you want, even put nitros on it, and it still won't go any faster. It will just get there faster.
If you build it for more power, raise the rev limiter, and gear it higher you'll get a noticeable top end difference.
By the way, just putting 22's on there with stock gearing you'll get a little more top end.
