KFX 400 Front Bearings & Steering
Old May 1, 2006 | 01:55 AM
Deathblow's Avatar
Default KFX 400 Front Bearings & Steering
Hello, I was wondering if you people could help me out.
When I turn my bars there is a little play before the wheels will turn. I tried to tighten the nut on the bottom for the steering stem but it did not help. How much play should there be before the wheels turn? Do I need to rebuild the steering stem bearings or whatever is in there?
Also, When I grab either front wheel and move it side to side there is also some play. I tried to tighten the hub nut but this didn't help. Should there be any play or do I need to rebuild the hub set up?
I checked my friends Blaster and he had no play in the steering or the wheels.
Thanks.
Old May 1, 2006 | 09:56 AM
KDIXER's Avatar
Sounds like your tie rod ends are a little wore.
Old May 3, 2006 | 05:04 PM
honda400rider's Avatar
Your bearings are toast. Replace the steering stem bearing and both wheel bearings. All the bearings aren't that expensive and its not very hard to do.
Ean
Dec 19, 2022 08:48 AM
Nondem
Feb 22, 2020 12:20 PM
Jul 23, 2015 07:53 AM
clsharky
Jul 13, 2015 02:07 PM
Scottma518
Jul 10, 2015 12:42 AM
