car question
Old May 2, 2006 | 02:06 PM
MnFriesen's Avatar
Default car question
so last night I was out driving around in my camaro, and I got on it alittle bit, and when it got to around 5k it seemed like it slips into neutral, and doesnt shift out....anybody have an idea of why this could be happening?
Old May 2, 2006 | 03:48 PM
LawdogB2's Avatar
I am guessing it's an auto. Is this a persistant behavior? Did it drive okay after this? What have you done so far to diagnose the problem? Is it pulling from a stop okay? Sounds like it is slipping. Check the fluid. If it is slipping, you may just need fluid and if not you are looking at a number of possible causes. Are you much of a wrench? I have rebuilt a few autos and they are no fun. I wouldn't even have tried if I weren't cheaper than I am lazy. Provide a little more specific info and it will be easier to help.
Old May 2, 2006 | 09:17 PM
MnFriesen's Avatar
Yes it is an auto. It takes off fine from the start. It normally only happens between first and second. I can prevent it from happening if I am on the gas 90% of the way...I am not much of a wrench but my dad is a mechanic.
Old May 2, 2006 | 09:47 PM
garrett5462's Avatar
sounds like a bad tranny or torque converter. Check check the ATF first.
Old May 2, 2006 | 09:49 PM
If your engine is bigger than the stock one or puts out alot more HP your gonna need a better and bigger torqe converter, the stock one wont handle it.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
