Need help with flywheel
Old May 6, 2006 | 06:27 PM
QUICKSAND04's Avatar
Default Need help with flywheel
I have the proper puller. I also applied heat. It still wont budge. Ended up stripping the threds on puller.
Any tips will help. Thank you in advance.
Old May 6, 2006 | 08:54 PM
Majorecho's Avatar
wow! thats not a good situation, I usually put a propane tourch on it for a few minutes and get it good and hot before I try to break it loose, I don't know what to tell you if you have stripped the threads on the fly wheel and puller- sorry dude!
That is a fine pitch thread I don't know if you could order a die and chase the threads or not.
You could also tig weld the the puller onto the fly wheel and than cut it off to reinstall- just hope you never have to take the motor apart again.
What work are you doing to the motor?
Old May 6, 2006 | 09:08 PM
Major
I am having it turned. Thanks for the info
Old May 6, 2006 | 09:48 PM
dsdrew's Avatar
MIne i heated it up put the puller on pulled as hard as I thought i could go..Then using a brass hammer lighty tapper the end of the puller..it poped right off..
Old May 6, 2006 | 10:21 PM
TheChosenOne's Avatar
The ticket is all in that little tap with a hammer. use half the pull and add a tap and you're in business
Old May 6, 2006 | 10:23 PM
dsdrew's Avatar
To big of a hit and the puller bolt will bend.. So carefull though
Old May 6, 2006 | 11:25 PM
yeah, hense use of the word tap.....with a small ballpin hammer, not a 10 pound sledge or anything. just use common sense and it will be fine.
Old May 7, 2006 | 05:12 PM
Thanks for the help fellas. I will try to tap on it. [img]i/expressions/face-icon-small-smile.gif[/img]
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
