You guy"s using 0w40 mobile 1 in your sportsmans,what do you think about it?
Mobil 1 is the best oil you can buy.
I have been running it in my sp700 for a few years now.
Just get full synthetic and the right weight (0w40). You do not need wet clutch oil in an auto trans machine that's only for the manuals with shared oils.
The ratings go up every year or so but if yours specifies "SG" then SH, SI, SJ is just the next better (newer rating) up the scale, just don't go down or lower (IE: SF) but it don't have to match exactly.
Jim
Jim
Any good name brand synthetic oil is as good as the Polaris oil and in most cases BETTER than the Polaris oil.
You are not doing yourself or your Sportman a favor by buying Polaris oil.
If you insist on using the Polaris oil you had best change it VERY often.
