help 01 trail boss 330 won't start
Old May 10, 2006 | 02:16 AM
neonacr99's Avatar
Default help 01 trail boss 330 won't start
So Im riding my bike one day and its running perfectly. The next day I go to start it. It starts on first turn over, idols, but won't do anything more than that. When I press the throttle, it just bogs and dies. THEN after it died it wouldn't even try to fire off anymore using the electric start or the pull. Heres what I know so far,
1. Plenty of spark, "I pulled the wire and made a bridge between the wire and plug". Also has new plug.
2. half tank of gas
3. I pulled the lines on the fuel pump to be sure it was pumping when the motor cranked. All is fine there too.
Gas will also move on the "out flow" side of the fuel filter. So I know thats not pluged.
4. The diaphragm on the carb. is sealed to, in other words theres no crackes in the rubber seal.
I have no idea what to check next. Somebody has to know something. My thanks to all in advance[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 10, 2006 | 07:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is the plug wet, is the air filter plugged?time to pull off the carb and clean it. its the next step if your sure your getting fire. was the plug a tan color when you changed it ? does it have good compression. just some more idears of what to check next.
Old May 10, 2006 | 08:26 AM
scootergptx's Avatar
Supersock
Hired Gun!
If it ran fine before, and now it idles, but that's it, sounds to me like you're going to be taking off the carb. Check the needle, maybe the clip has broken.
Also may want to be sure on what you have. The 2001 was a 325. They do have different carbs.
Old May 10, 2006 | 02:03 PM
neonacr99's Avatar
Yea my bad its an 03! Um the plug was tan though. Im taking off the carb today! I hope I can see somthing. Is it possible for the timing to be off?
Old May 10, 2006 | 07:54 PM
Supersock
Hired Gun!
Well at least the mixture was good. While you're at it, you may want to check the valve clearence too.
Old May 17, 2006 | 02:59 PM
neonacr99's Avatar
Thanks, but man it was like 1 gallon of water in my 2 gallons of gas! Dumb *** Chevron gas.
Old May 17, 2006 | 04:30 PM
Supersock
Hired Gun!
And they only want to charge 3 bucks a gallon. [img]i/expressions/face-icon-small-confused.gif[/img]
wildbill59
Jun 20, 2015 02:26 PM
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
