help 01 trail boss 330 won't start
So Im riding my bike one day and its running perfectly. The next day I go to start it. It starts on first turn over, idols, but won't do anything more than that. When I press the throttle, it just bogs and dies. THEN after it died it wouldn't even try to fire off anymore using the electric start or the pull. Heres what I know so far,
1. Plenty of spark, "I pulled the wire and made a bridge between the wire and plug". Also has new plug.
2. half tank of gas
3. I pulled the lines on the fuel pump to be sure it was pumping when the motor cranked. All is fine there too.
Gas will also move on the "out flow" side of the fuel filter. So I know thats not pluged.
4. The diaphragm on the carb. is sealed to, in other words theres no crackes in the rubber seal.
I have no idea what to check next. Somebody has to know something. My thanks to all in advance[img]i/expressions/face-icon-small-smile.gif[/img]
2. half tank of gas
is the plug wet, is the air filter plugged?time to pull off the carb and clean it. its the next step if your sure your getting fire. was the plug a tan color when you changed it ? does it have good compression. just some more idears of what to check next.
