Alot of White Smoke blowing out of Exhuast
Old May 15, 2006 | 10:55 PM
YAMMYOWNER's Avatar
Default Alot of White Smoke blowing out of Exhuast
Let me give you some background info. I have a beartracker 2000 2wd 250. It blew a gasket and started to leak oil, i took it to the shop and and they fixed it. But they found a load of sand in the engine, two bags worth. I don't know how this happened and everyone i talked to said that the only way this could have happened is if someone poured it into my oil. My bike sounded and ran fine untill i noticed it was leaking oil. Now it's blowing out tons of white smoke and it never did this untill it came out of the shop. At first when i got it the motor sounded real clanky like metal against metal, but now it sounds fine. What could the problem be? Thanks in advance.
Old May 16, 2006 | 02:35 AM
ghostbuster's Avatar
if it is liquid cooled, than you definitly have a head gasket leak which is leaking coolant into the engine.
coolant and oil dont mix, and will take out bearings.
Old May 16, 2006 | 11:07 AM
YAMMYOWNER's Avatar
it's air cooled not liquid cooled
Old May 16, 2006 | 01:09 PM
squeege's Avatar
AAHHH...The OL Bag of Sand Trick.....that one turned a lawnmower into a go-kart once
Old May 16, 2006 | 07:20 PM
YAMMYOWNER's Avatar
any one else have suggestions
Old May 16, 2006 | 11:47 PM
Doctorturbo's Avatar
GOT BOOST!
From the description, your engine is done. Something got fubared on the rebuild.
Take it back to the shop that did the rebuild and have a talk with them.
Oh; and you pissed someone off REAL bad. [img]i/expressions/face-icon-small-wink.gif[/img]
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
