Tire Pressure
Old May 16, 2006 | 10:48 AM
Mainehunt's Avatar
Default Tire Pressure
I have stock tires on my Rancher 4x4. (Originals were pretty worn, but I just bought new take-offs [dirt-hooks] from an '05 Rancher....all 4 for $60!)
Anyway, the tire place put 10 PSI in them. They seem to get good traction with this pressure, but I notice that the tag on the rear fender says 3.6 PSI.
Do I really want that small amount of pressure???? Man that seems low.
What do you all run for pressure??? I split my riding between trail rides and very slow crawling through the woods.
Thanks, Kev
Old May 16, 2006 | 10:56 AM
arctichondacat's Avatar
I think that is way too high, you would be vulnerable to punctures. I have blackwaters which are bigger than stock and run 4 in the back and 3.5 in the front.
go with what the factory says.
d
Old May 16, 2006 | 11:46 AM
Mainehunt's Avatar
d
Thanks, I'll try that lower pressure tonight. I guess that If I was impressed with the traction I was getting w/ 10 psi, I should love the traction at 3-4 pounds!
Kev
Old May 16, 2006 | 11:58 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The tire places pump them up high, to seat the bead. Then they leave them that way...........
Run what it says in your fender!
Old May 16, 2006 | 12:34 PM
z4hundo's Avatar
SOME tire places leave them at high pressure......not mine- we check with the owner if the machine is not there to find out what they are going on and let the pressure down to stock. Belive it or not not ALL tire guys are dumbasses
Old May 16, 2006 | 04:16 PM
Mainehunt's Avatar
The place that changed my tires actually had to inflate the tires up to 50-PSI in order to get nthe beads to seat. (Even though it says on the tire not to go that high)
They then reduced the pressure to 10 PSI. This is what they recommended.
I will reduce the pressure to 3.6 PSI.
Kev
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Hw00d
Sep 10, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
