300ex sprocket combinations
Old May 16, 2006 | 08:14 PM
hondaman300ex's Avatar
Default 300ex sprocket combinations
does anyone know whicjh sprocket combinations will make the ex the fastest?
Old May 16, 2006 | 08:37 PM
TractorPacker's Avatar
Do you have a balloon?
14/36 will make it scoot, but you better bring power.
Old May 16, 2006 | 09:31 PM
thanks for the info. gear ratios have always amazed me also confused me .and do you also know what the 300ex comes with stock. how many teeth? thanks
Old May 16, 2006 | 09:43 PM
13/38 is the stock ratio.
Old May 16, 2006 | 09:45 PM
is there alot of difference in the 13/38 and the 14/36?
Old May 16, 2006 | 09:57 PM
A tooth in the front is is about 3 in the back. With a stock engine, you might beable to get away with a one tooth change in the rear.
Old May 16, 2006 | 10:01 PM
so i guess it wouldnt even be worth messing with since im running a stock engine right now . would it?
Old May 16, 2006 | 10:17 PM
Your best bet would be to start with an air filter and exhaust. Those things are stuffed up, and need to breathe.
Old May 16, 2006 | 11:33 PM
weewane's Avatar
go with a 12 up front and leave rear stock it will give you alot more out the hole that is what i am running it will lower the top speed of the bike but who cares how often do you run wide open
Old May 19, 2006 | 01:37 PM
deonion's Avatar
I have a 95' 300 and i am running 13/33 gears but if your atv is stock I would not run that gearing all I have is a full exhaust system KN filter and it is jetted.
I ran 13/34 before I got the 33 and I liked it more. I could climb hills with the 13/34 gearing in 2nd most of the time but now I have to climd in 1st on long hills. I am about 10 ft behind a big bored 250x when we are both full throttle.
