got +2 a arms,alignment problem
Old May 17, 2006 | 12:26 AM
superevil's Avatar
Default got +2 a arms,alignment problem
i just put +2 +1 full flight racing a arms on,and when i compress the suspension,both wheels turn out,and when i like wheely or something both wheels turn in. What am i doing wrong here?
Old May 17, 2006 | 02:52 AM
Glamis700's Avatar
Did you set your toe in????
If you set all the angles to spec, then what you have is bumpsteer. This is inherant with poorly designed suspensions that are purchased for little money.
Old May 17, 2006 | 11:08 AM
superevil's Avatar
I thought bump steer was from hitting something with one wheel while your riding.Im talking about when the quad is just sitting there and you push down on the front end the wheels will turn in,and when you lift up on it the wheels will turn out.I have the shocks off and im just lifting the a-arm/spindle assembly up and down,and the wheels are turning in and out while i do it
Old May 17, 2006 | 12:33 PM
asfasasu3's Avatar
The term "bump steer" is when the tires travel up and down with the suspension, the action they take as far as toe in and toe out. Meaning, the tires both turn in or out while raising and lowering them. Most of the higher end atv's made have very little "bump steer" from the factory. While cheaper atv's will have more due to the cheaper R&D that has went into them. (I'm not saying your atv is cheap, just not as much R & D has went into it to prevent this) Its almost impossible to keep from having some built in bump steer. Changing the a-arms has no effect on it, it just shows it more. The more travel you have, the more bump steer it will have. The solution? Try and find a happy medium that you can live with. Or change frames, steering stems, tie rods, steering nuckels, ect help correct it.
Old May 17, 2006 | 07:31 PM
superevil's Avatar
When you lift the front end,the wheels only turn in badly during like the bottom 2 or so inches of travel.Other than that they stay relatively straight
Old May 17, 2006 | 07:56 PM
warriorryder's Avatar
try adjusting your tie rods and ends...
sixsixT's Avatar
Did you remove your tie-rod ends from the spindles? If you put aftermarket ones back on and put the tie-rods on the top side of the mount instead of on the bottom side where they belong you'll get the problem your discribing.
Cole Hadden
Jun 15, 2025 09:05 AM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
musselmark
Jul 17, 2015 02:40 PM
