warrior smoke
Old May 17, 2006 | 12:24 PM
Lukemysta66's Avatar
Default warrior smoke
when i hammer the gas and let off it lets out a little blueish color smoke. i overfilled the oil at first could that be the porb. it has a fairly new top end too so....
Old May 17, 2006 | 03:22 PM
gassrx's Avatar
donrt over fill the machine it can wip the cam,crank oistons because it airates the oil and air compresse so it will slowly starve the motor . but it could be the valve seals leak a little does it do it on start up. you can take a little bit of baking powder and sift it into the intake while running at a fast idol not a lot just dust it . this will remove the scrorch oil and let the rings re seat. call me if you need more help 402 270 1768
Old May 17, 2006 | 05:25 PM
it smokes on start up only if you rev it up. if you just start it it will sit with no smoke. just like when rideing, only when you get onto the gas will it smoke.
Old May 18, 2006 | 05:26 PM
nvm the smoke prety much stopped. i think i filled the oil a lil too much
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
