Banshee aftermarket flywheel key?
Old May 18, 2006 | 04:39 PM
cmatthews24's Avatar
Default Banshee aftermarket flywheel key?
Vitos makes an aftermarket flywheel key at a pretty good price. They say it makes about 2 hp all through the powerband. My question is does that key make my banshee less reliable? Such as harder to start?
Old May 18, 2006 | 06:42 PM
GITRDUN's Avatar
I cant answer your question, sorry. But i would add that the degree keys are prone to breaking. I would suggest getting an adjustable timing plate instead of a degree key. Their not too expensive anymore and are adjustable as oposed to just a solid timing change.
Just my $.02 from experience.
Old May 18, 2006 | 08:26 PM
enFORCER's Avatar
Yep, I agree.
Old May 19, 2006 | 07:24 PM
JCJBanshee's Avatar
If you go with the Vitos key make sure to use loc tite in the nut holding the flywheel on or it may eventually back off and let the flywheel rattle against the case and it sounds like the motor just came apart. Trust me.
Old May 20, 2006 | 11:59 AM
TractorPacker's Avatar
Do you have a balloon?
I was told those keys, will shear off, also. My engine guy alterd the flywheel,to advance the timing. I think he just grinds the slot for the keyway wider. It could be cheaper, than a timing plate, if someone knows what they are doing.
Old May 20, 2006 | 12:19 PM
midnite's Avatar
It will rob you off a couple of mph on top end. If you want a more noticable bottom end for trail riding, then advance your timing. I've tried it both ways and now run 0 degrees advance {I may even retard the timing 2 degrees for even more top end power. Any thoughts on that enforcer?} I modded my stock timing plate, but since have bought the ricky stator 200 watt job with their timing plate. If you have a die grinder, and an hour to kill, just mod your stock plate. If you don't want to **** with that, the ricky stator plate looks pretty trick for $40.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
cboler9
Sep 24, 2015 08:35 PM
