Is my CDI Bad???
Old May 20, 2006 | 03:46 AM
Deathblow's Avatar
Default Is my CDI Bad???
Hello,
I have a 04 KFX400 and just rebuild the steering stem bushings, seals ect. I also changed the sproket to a 13 tooth and modded the airbox, oil change, plug ect. I put it all back together and tried to start it. It turned over maybe 2-3 times and then stopped. Now when I hit the started button all I hear is the starter switch click. I am thinking that the CDI is bad. I hooked an amp meter to the CDI plug and the voltage raises when I press the start button. Since the CDI is around $100.00 and is not returnable because it's electrical I was wondering if you thought my CDI was bad. Is there anyway to test my CDI? When I plug the CDI in my oil light will come on and when I unplug it the oil light will go off so I am kinda confused whether it is working or not. Any help would be greatly appreciated.
Thanks.....
Old May 20, 2006 | 04:17 AM
ThrashAndCrash's Avatar
You need to check your starting system, not the CDI........I am not sure of the setup on the KFX400 but check the starter relay and the starter for power
