Gas pouring out of carb
Old May 20, 2006 | 09:45 PM
Gospel's Avatar
Default Gas pouring out of carb
I ahve an 87 Trx 125/fourtrax that I am trying to get running, it has three nipples on the side of the carb, one for the line straight of the gas tank but what about the other two, my buddy said just run a hose connecting them together, now gas comes out the front of the carb, are these supposes to just leak some gas????????????? Help I don't get it!!! Thanks Shane
Old May 21, 2006 | 12:21 AM
1988TRX250R's Avatar
If they are on the side of the carb, they are probably float bowl vents. They need to vent to the atmosphere and should not be connected together if there is more than one. If you are leaking fuel out of the venturi, your float valve may be bad and not shutting off the flow of fuel into the float bowl.
Old May 21, 2006 | 02:43 AM
quicksilver's Avatar
there is probably 2 vents and one overflow tube. The overflow is usually mounted in the float bowl part, and the vents are part of the carb body itself. Just routing the vent tubes together would not work, they need to be vented to the atmosphere for the carb to to work right.
Old May 21, 2006 | 11:39 PM
XxBamBam2xX's Avatar
i would say the same as 1988TRX250R there might be something wrong with your float not closing
Old May 22, 2006 | 01:39 AM
gassrx's Avatar
good answer
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 19, 2015 10:13 AM
Shifts
Jul 3, 2015 07:59 AM
