Used Parts
Old May 21, 2006 | 04:19 PM
Supertom's Avatar
Default Used Parts
Hey guys and gals,
My daughter has a '01 Trailblazer 250 that I am trying to fix for her, I am needing the inner part of the primary clutch, not the entire clutch just the part that is on the crankshaft. I cannot find it new without buying the entire clutch. My budget doesn't allow for a new clutch....Thanks for any and all help.
Supertom
Old May 21, 2006 | 05:28 PM
trailblazermudrunner's Avatar
Default Used Parts
ummmm what parts do you need for the insides? if its only a cuppel you could probley go to the dealer in ur area and pick them up...but also what eles is rong with with the clutch?
Old May 22, 2006 | 08:04 AM
ftwflh's Avatar
Default Used Parts
It is not a good idea to use differant parts from other clutches because thte assymly comes balanced from the factory.Check out Ebay for polaris clutches.
Old May 22, 2006 | 03:30 PM
Supertom's Avatar
Default Used Parts
Nothing wrong with the clutch, I pulled it to get the crankshaft out and in the process I broke the inner side of the clutch that is pressed on the crank.
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
