Predator performance, whats next?
Old May 22, 2006 | 12:11 PM
HPDracer's Avatar
Default Predator performance, whats next?
I have a 2006 troy lee edition predaor with HPD cams, Vortec rev box, Rath racing head pipe, white brother exhaust and I want more power at top end but i dont want to lose any in the bottom range. Is there anything I can do. I have heard people say that a carb makes a bid diff. on these bikes, is this true? What about 114 octane fuel with my rev box set on high octane. Thanks in advance.
Old May 22, 2006 | 04:54 PM
heatseeker8's Avatar
Advancing the timing will not make 114 octane work any better. You ned a high comp. piston along with that.
A Honda 450r carb does the trick..however I think there is a throttle cable issue.
Also might want to look inot a Honda Civic intake..you can find endless info at predatorowners.com
Old May 22, 2006 | 04:55 PM
crashby's Avatar
bore it out and get bigger vavles and heavy duty vavle springs
Old May 22, 2006 | 05:10 PM
HPDracer's Avatar
What about any aftermarket carbs. I am runing 93 octane now and i waws wondeing if the 114 would do better. I got pretty good low end though so even if i do any more will my high end get better if the sprockets are stock
Old May 22, 2006 | 05:19 PM
XShowtimeX's Avatar
Go to nicholascycle.com and do the racing carb mod and his intake.
Old May 22, 2006 | 05:34 PM
spyder6's Avatar
the nicholas cycle racing carb is fantastic it will do wonders for your set up, as far as your exhuast goes i would reccomend putting a high flow turn-down tip on, like i have on my predator. i have an 06 LE and with a round K&N filter clamped onto the carburator and then the high flow tip, im running a 175 main about 1500 feet above sea level.
when you wake these preds up, they fly
Old May 23, 2006 | 10:33 AM
Speedwerx's Avatar
If not the carb you shoudl consider our 600 cc kit there bullet proof and work wonders.
Sep 30, 2015 01:37 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jankerstien
Sep 21, 2015 03:09 AM
Elkaholic
Sep 6, 2015 02:44 PM
