Cylinder Rebore
I recently put in a new piston and ring set in my 250 Trailblazer. I had to have the cylindar rebored .020" over. Should I need to reject after this? How can I tell if and how much? Thanks.
When I rebored my 94 250 Trailblazer I went .010 over and didnt have to rejet. But you probley could go up 1 size in jet and be ok. Just check your plug to see it is running lean. Also at wide open throttle back off the throttle to 3/4 and see if it picks up speed or stays the same. A jet will run around $5 to $10 depends where you buy it.
