Finnaly a 450R
Old May 23, 2006 | 12:04 PM
Hemiman76's Avatar
Default Finnaly a 450R
Im finally getting one. Mods will be few at first. Whats the best things to do. My only one I'm thinking of is AG nerfbars. Whats your thoughts.
Old May 23, 2006 | 04:44 PM
crashby's Avatar
AC nerf bars are really nice. Get the propegs with heelguards. You should also consider an exhaust and jet kit, summit front bumper, and a bigger rear grab bar. you should also get some good tires and rims.
Old May 23, 2006 | 05:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Here is what I do to any new quad, in the order I do it as my finances allow: Nerf bars (a must!), full chassis and swingarm skid plates, bumper, tires and rims, handlebars, steering damper, shocks and maybe a-arms. (In sharp turns at low speed, it will wheelbarrow a little bit. I'm running Maxxis iRazr's on ITP rims. The tires are wider than stock and the rims are wider and have a greater offset. This makes the quad a few inches wider than stock, and cures those problems. (I think the real "problem" may be the stock tires????))
Do the suspension first, before you mess with the engine! All the power in the world isn't worth anything if you don't have the suspension to handle it (although stock suspension is pretty good on this machine)! Mild mods to the engine: Header and muffler, and HRC kit.
Old May 24, 2006 | 11:16 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
You need to uncork it at a minimium. I added a proflow intake with the K % N filter and a DMC slip on exhaust. I up the main jet from a 120 to a 170 and from the stock pilot 138 to 142 and replaced the nonadjustable needle with the needle from the crf 450 carb. Start with the 3rd clip. It's given me all the power this old man can handle. I cant imagen what the HRC kit will do, but this sure is a big jump from stock.
Old May 24, 2006 | 12:26 PM
Red Rider
Oh yeah, forgot ProDesign intake kit with foam (made by UNI) filter (don't trust your precious motor to K&N!), and IHS Racing airbox lid with Outerwears.
Old May 24, 2006 | 03:13 PM
dirthead's Avatar
reconranger- Did you say that by going with +1" offset rims and razrs that greatly improved the handling of the 450r....Im still trying to decide between the 450r and the 700r and the handling of these 2 quads will be the deciding factor...
Thanks
Dirthead
Old May 24, 2006 | 03:48 PM
Red Rider
The ITP rims have a greater offset than stock, and the rears are wider as well. The tires are also wider than stock in the rear.
All this combines to make it about +3" in the rear and +2" in front. A nice little bit of added stability (without the expense of a-arms or an axle), yet not so wide that the quad can't be ridden on a tight trail.
I am going to write a rider review of the iRazr tires. Watch for it in the tire section.......
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Asaran
Oct 8, 2015 11:14 AM
Aug 5, 2015 02:10 AM
MOTOWN
KTM
Dec 10, 2002 08:49 PM
