2006 LT Z50 Rev Box?
Old May 23, 2006 | 09:03 PM
Hibrass's Avatar
Default 2006 LT Z50 Rev Box?
OK...
I have been working on my sons 2006 Z50. The good news... Suzuki provided a 12volt switch connection so wiring in his new light will be easy...
The bad news is I have adjusted everything on this engine and there is just no speed left. The reason for this is the CDI (IMHO).
Does anyone know of a REV box that might replace the KOKUSAN DENKI model JI43 that is in the bike now??? I really think that is someone had a unlimited rev box this bike would be a winner. It has tons of lowend power and should be pretty fast if a person could get by the Rev Limiter...
Any suggestions are appreciated!!!
Hibrass
Old May 24, 2006 | 02:36 PM
Hibrass's Avatar
Bump for the lunch crowd... :-)
Old Jun 6, 2006 | 11:43 AM
camovinson04's Avatar
Hey Hibrass, just bought my son a Z50 a few weeks ago, love it. He's 3 and weighs only 35 lbs, great for him. You said you found a 12 volt switch connection to wire a light? Could you tell me where it is? Would like to add light to the front and rear. Thanks, hope you have good luck with your mods. Later , Camovinson04
Old Jun 6, 2006 | 04:58 PM
Hibrass's Avatar
Camo,
The 12 volt connection (Male Pin) is located on the left front fender... It is a low amp 12 volt feed so don't try and run a High Wattage light off of it.
Good Luck,
Hibrass
Old Jun 10, 2006 | 03:57 PM
Hey Hibrass,
Thanks for the info. Found it , Can't wait to wire it up.
Later. Camo
Old Jul 9, 2006 | 07:06 PM
Hey Hibrass,
Couple more questions for you. Do you only have one light on the front and one on the back due to wattage limitations ? Also is 35 watts for a headlight considered low wattage? I only seem to find this light as the lowest watt. Thanks for you advice. Hope your mods are coming along, later, Camo
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
dwhipper61
Aug 27, 2015 11:01 AM
