engine start up
Old May 24, 2006 | 04:58 PM
joepizi's Avatar
Default engine start up
I just got an new 06 wolverine 450 (30 miles on it now) and every time I start it up cold (outside temp is around 50-60F), I have to apply some throttle continuously for a few minutes or it will die. After it warms up, I can release the throttle and it will idle nicely but it never idles without throttle when the engine is not warm. Is this normal and if so will it go away after the engine is broken in more, and why do these engines take so long to warm up before they can idle normally?
Old May 24, 2006 | 05:17 PM
Lukemysta66's Avatar
are you chokeing it when you start it? some 4 wheelers require it no matter wut temp
Old May 24, 2006 | 05:31 PM
joepizi's Avatar
I have tried it with no choke, half, and full, all with the same result. No choke seems to cause it to die sooner, and the manual says full choke should only be required in temperatures below 40F.
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
Thanos
Jul 12, 2015 08:40 PM
alix
Jun 28, 2015 03:28 AM
1000gade
May 27, 2015 12:37 PM
