K&N AIRFILTERS
Old May 24, 2006 | 05:56 PM
Titans's Avatar
Default K&N AIRFILTERS
Does a K&N air filter really give you more power over a normal Polaris Predator 500 air filter? Can you feel the difference? I was told that just getting a k&N is better than getting a whole power kit, is that true?
Old May 24, 2006 | 07:54 PM
Titans's Avatar
Come on people, i'm not just posting questions for my health. 16 of you read it and no one replied. PLEASE REPLY, REPLY, REPLY,REPLY,REPLY...............!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Old May 24, 2006 | 08:51 PM
gates59's Avatar
They don't give more hp. Maybe if you had a dyno and check it that way but I have had many polaris atv's and there is no noticable difference. Alot better for cleaning thought. Pays for itself in a few months.
Old May 24, 2006 | 11:00 PM
beltburner's Avatar
they also dri-out if u swamp your bike.the paper ones just fall apart
Old May 24, 2006 | 11:27 PM
scrammersam's Avatar
i noticed some difference nothing huge. i think it makes a more noticeable difference if you mount it directly to the carb and dont use a airbox
Old May 24, 2006 | 11:39 PM
YFZracer12's Avatar
the more air you get the more power you have considering on your air/fuel mixture. the farther you get the air filter away from the carb by using a plastic tube (boot) that most quads come with the more bottom end you will have
Old May 25, 2006 | 02:46 AM
ScramblerXLE's Avatar
The K&N doesn't give you any additional horsepower to speak of. I bought mine because the paper one was dirty and I figured it would be cheaper in the long run b/c of being reusable. They are also more maintanence and if you're not prepared for that they can damage your engine in the long run, so if a new paper filter every so often is no big deal for you, it could be the better way to go.
ALSO: do a search on my previous post regarding K&N filters coming over oiled from the factory. mine was so bad that it made my Pred run noticably rich, but after re-oiling it myself it's fine. I've heard this is actually fairly common...
Old May 25, 2006 | 04:50 AM
gates59's Avatar
I have never oiled mine. I don't see the point of it.
Old May 25, 2006 | 07:31 AM
Titans's Avatar
How come it says that it gives you 15 more horsepower in the catalogs? Dennis Kirck does.
Old May 25, 2006 | 07:49 AM
The point is to catch the dirt other particles that may otherwise enter the engine. Since the K&N filter is made of cotton gauze, the K&N box tells you itself that the pores in the cotton are nowhere near small enough to effectively filter without the help of an oil to grab dirt. It is a very important mainenance procedure and if you value your machine, you should really begin doing it.
For one, I always thought those ads said 10-15% gain not 15 horsepower! (15% is still B.S. just not as much as 15HP) Also, when a predator makes only around 46 horse power stock, how do you expect to gain 33% with just an air cleaner? it's not possible. Especially since a full exhaust system will only grab you around 6HP. The K&N is a nice filter and the reusability is a plus, but NO WAY will you see gains over a fraction of a horse.
