plz help 350 warrior
Old May 28, 2006 | 01:02 AM
ethansouva's Avatar
Default plz help 350 warrior
ok i own a 1997 350 warrior and it was running fine then i put it away and the next day i get it out and it starts up fine and idles good but as soon as i push the gas it dies out on me and i thought it would be the main jet in the carb so i cleaned it out like 5 times now still does the same think so i tryed changing the cdi box still didnt work and now im out of ideas so if anyone could give me any ideas it would really help me.
Old May 28, 2006 | 01:04 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
parking brake? what mods does it have?
Old May 28, 2006 | 01:07 AM
ethansouva's Avatar
just nerf bars and a bumper but what should i check about the parking break?
Old May 28, 2006 | 01:11 AM
paintballbanshee's Avatar
that happens with mine when the idle is set too low, try raising it a quarter of a turn
Old May 28, 2006 | 01:47 AM
ethansouva's Avatar
the parking break worked thanks it was jus on a lil bit but i pushed it back and it worked thanks again
in
Old May 28, 2006 | 11:40 AM
recon99's Avatar
A lot of us yamaha owners completely remove the useless parking brake system, bypass the sensors, and get a nice aftermarket clutch perch. Saves weight, and makes working on it less of a hassle.
Old May 28, 2006 | 09:53 PM
98warriortaz's Avatar
Today I just brought home a 98 warrior that hadnt been run in about 3 years. I cleaned out all the old gas, cleaned out the carb and air filter and replaced the spark plug. Still had the problem described here and now I'll have to check the parking brake to see if there is an issue. If not I think I'll have to dig deeper into the carb. I just did a quick blowout.
Great forum, found help even before I asked!
Old May 28, 2006 | 10:01 PM
bberck's Avatar
There are 2 plugs that go in the clutch perch just unplug the top one. It that fixes the problem its the parking brake.
Then you can just un plug it under the fenders or cut it off. If want to remove the bottom one to put a different perch on you will have to splice into it and connect the wires together. This is the clutch sensor, with it just unplugged you can only start in nuetral and it will die if shift into reverse.
Old May 28, 2006 | 11:49 PM
Speedy2222's Avatar
hahahahahahahahahaha are you serious???
o you are...
all you have to do is take the hood off.. unplug the 2 wires fro mthe perch and then rom the harness... then plug the harness wires together
Old May 29, 2006 | 11:15 AM
Thanks for the info bberck, I unplugged the parking brake sensor but it still wont run smooth when I give it throttle. Missing and backfiring. Idle is OK. Guess I'll have to get deeper into the carb, maybe get a rebuild kit.
I was hoping to get lucky and have it run after a good cleaning, but the seller gave me $100 bucks back once I said it wouldn't run.
