belt noise 05 400 sportsman
Old May 28, 2006 | 09:13 PM
butch1234's Avatar
Default belt noise 05 400 sportsman
i have a 2005 400 sportsman with no ebs when i slow down and release the gas completely the belt rattles and it sounds like a loud flapping or thumping sound i just purchased the used with 330 miles on it is this normal noise or should i get it checked at the dealer seams like belt engages and pulls good just noise no slipping any thoughts or did any body else have on with this sound and get it fixed?
Old May 28, 2006 | 09:25 PM
Toyeboy's Avatar
Definitely get it checked by the dealer because I put 2300 miles on my 04 400 sportsman and it never did that so I can't imagine it being normal or good for the belt.
Old May 28, 2006 | 10:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its not under warr. any more take the cover off your self and see what its doing.
Old May 28, 2006 | 10:36 PM
butch1234's Avatar
do i need a new cover gasket after removing it or can i re use the old one
Old May 28, 2006 | 10:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you shouldnt have any trouble using the old one its not like a base gasket or anything, just like rubber. just dont ripper it apart. clean it while you have it off as well blow all that belt dust out and check for any broken or worn out parts. make sure the belts in good shape and not missing cogs or burnt.
Old May 28, 2006 | 10:49 PM
butch1234's Avatar
i see in your pics you have a yellow 05 sportsman no noise in this when you let go the gas or does it have ebs
Old May 28, 2006 | 11:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its my wifes 06 450 w/out ebs. it only wines when you let off the gas as its going down a hill or something. its normal for it to do that. its just the belt free wheeling in the primary clutch when the clutch is disengaged. if you stay on throttle a little bit it keeping the the belt engaged and slow it down a little w/ the engine. if your hearing a flapping sound it could be belt slap. when you have the cover off and the machine in park or neutral slowly rev up and watch the belt engage and rise and drop thru the clutches and then release throttle and watch it disengae and see if is doing this all the way correctly. make sure there isnt too much belt defection ( with the machine off).
Old May 28, 2006 | 11:13 PM
scrammersam's Avatar
is your cover dented in at all. it is made with just enough clearance for the belt. if its not that. then check belt deflection for sure
Old May 29, 2006 | 07:00 AM
butch1234's Avatar
how much play or deflection is the proper amount and if to much how is it fixed is there an adjustment
Old May 29, 2006 | 08:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im not really 100% sure what the proper deflection is, i but i would go w/ around 1 1/4" make sure your belt is setting high in the secondary,around 1/8" above is ok. i beleave you can adjust your engine in the mounts to make sur its line up right. at least this is how i always do my own.
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
toonces
Jul 31, 2015 09:27 AM
trouttracker
Jul 20, 2015 11:54 AM
D-Hagz
Jul 4, 2015 02:19 AM
