Running without an exhaust
Old May 31, 2006 | 08:33 PM
YamahaRider8998's Avatar
Default Running without an exhaust
can i run my warrior with no slipon just right out of the fmf powerbomb header, i tried and it gave alittle more accel and power, very little, and it sounded amazing. Is that bad
steve
Old May 31, 2006 | 09:03 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
no, not enough back pressure, and it leans it out... + i bet it's loud as fock
Old May 31, 2006 | 09:32 PM
it was loud but really nice souding, it wos very deep and bumbling, it was cool, but ok thanx, but wat is back pressure and lean it out means the carb gets lean or it literally leans out off the quad
steve
Old May 31, 2006 | 09:56 PM
Warrior02man's Avatar
leans out means that the air and fuel mix is altered.. rich emans too much gas and not enuff air which fouls plugs.. and lean means too much air n not enuff gas.. and thats not good it cooks ur piston..
i just did it on my cr125 and need to fix it.. new piston and boreing.. dont do it cuz it will run u 300$ about with labor and parts.
just put it back on or get a HMF pipe for 200 with a nice sweet rumble to it.
Old May 31, 2006 | 10:19 PM
Speedy2222's Avatar
definition:
Pressure exerted upstream in the circulation as a result of obstruction to forward flow, as when congestion in the pulmonary circulation results from failure of the left ventricle.
lamens terms...
it's a constant force on the engine to keep it running and not just free spinning
Old Jun 1, 2006 | 09:12 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Prolly not too good for your hearing either....
Old Jun 1, 2006 | 02:14 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
i'd be more worried about starting a forest fire rather than losing my hearing.....
Old Jun 1, 2006 | 03:59 PM
Pelphrey's Avatar
HAHAHAHA
That or possibly burning my own right leg off...
Old Jun 1, 2006 | 09:21 PM
maddog56's Avatar
You can do it, just dont expect a whole lot of sympathy from others when you ask for help to get it running again lol.
Yeah, as was said it's a bad idea.
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
VRRRRT
Jun 27, 2015 09:38 AM
joshuafromny
Jun 22, 2015 05:30 PM
alex_2011
Jun 9, 2015 10:12 AM
blaze_master
May 26, 2015 11:18 AM
