i need help extremely bad
Old Jun 1, 2006 | 02:28 AM
makeemfast's Avatar
Default i need help extremely bad
my 2001 yamaha waqrrior is blowing fire out of the exhaust and its sluggish in all gears your advice would be greatly appreciated thanks
Old Jun 1, 2006 | 03:26 AM
RaptorRookie's Avatar
Need more info. Does it have a pipe? Whats your jetting? Any other mods? Has it always done this, started recently, happens once in a while? We can help ya more when we know more.
-Brandon
Old Jun 3, 2006 | 12:01 AM
makeemfast's Avatar
it haas a white brothers e-series exhaust k&n air filter and a little smaller than stock tires but i do not know the jetting
Old Jun 3, 2006 | 12:03 AM
makeemfast's Avatar
it is a 2001 yfm350 yamaha warrior
Old Jun 3, 2006 | 12:14 AM
tdragano's Avatar
If it's backfiring flames on deceleration, it sounds like you've leaned out somehow. Check the intake rubber between the carb and the head. Also check for any other air leaks that could be letting extra air into the fuel mixture. On the flip side, if the fuel supply is being restricted somehow, a lean condition could also result.
What happens when you run with the choke on? This should richen the mixture and help confirm that the problem is indeed a lean condition.
Old Jun 3, 2006 | 12:20 AM
makeemfast's Avatar
thanks alot i will try this first thing tomorrow your help on this is very much appreciated
Old Jun 3, 2006 | 12:32 AM
makeemfast's Avatar
but that is exactly what it is doing i can give it some gas and when i let off it backfires with fire
Old Jun 3, 2006 | 01:23 AM
PADZZ's Avatar
My friends Raptor was blowing flames too. His head pipe had a crack in it somewhere. Maybe look for some kind of leak??
Old Jun 3, 2006 | 03:14 AM
makeemfast's Avatar
i will thanks
Old Jun 3, 2006 | 10:44 AM
Scooter86's Avatar
Knows Old ATV Questions!
If the quad was not rejetted after putting on the exhaust, you are to lean! If it has run fine with that setup in the past then you likely have another problem. Does the problem clear up or get better if you run with the choke on? If so, I would look for an exhaust leak, possibly right where the header attaches to the engine. Also check the rubber intake boot like mentioned above.
