HOT SEAT PIPE OR DG FOR SPORT
im just bought new holeshots and itp's all the way around and now for the pipe i need some advice, ive heard a lot of bad about fmf so im not even thinking about that so whats the best?
FMF is one step above DG, and DG isn't much. I would either go with the RCR stage 1 kit, or go with www.hpd-inc.com they make awesome pipes and alot of other parts also. Let me know if you need anymore help.
you must check as stated earlier above,but it all depend on what you want your quad look about,or sound about,
do you plan to do more mods in the future?
do you want an free heat leg pipe or the standard side stinger?
all those factors will lead you to get the right pipe for your engine setup.
Originally posted by: 660bonez
DG sucks and there costomer serivce is horriable i just put a white bros pipe on mine and for a slip on i noticed a huge difference
Like Scramblered stated there is alot of things to factor in on a 400 pipe.My personal favorite is the Dynoport but HPD,RCR,Aaen and HSP are good but you have to take into cnsideration how you ride.I like low end power along with good pull through the throttle.Dynoport is what gives that but you dont get the topend or the zap as you do with the others.
Stay away from the DG it is impossible to clutch it.
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
